Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Check NET MGT Port Status LEDs
Check Power Supply Status LEDs
Display Faulty Components (fault_state)
Display Faulty Components (/SP/faultmgmt)
Determining the Alarm State of a Component or System
Display the General Alarm State of Systems and Components
Oracle ILOM Target Alarm States
Display Oracle ILOM Sensor Status
Determine Oracle ILOM Sensor Target Types
Evaluating a Voltage Sensor Alarm
Evaluating a Temperature Sensor Alarm
Evaluating a Speed Sensor Alarm
Evaluating a State Sensor Alarm
Evaluating a Presence Sensor Alarm
Presence Sensor Alarm Conditions
Access the Oracle ILOM CLI (NET MGT Port)
Enter the Restricted Linux Shell
Exit the Restricted Linux Shell
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
-> show /SP/logs/event/list Class==class Type==type
where you choose class and type from the table in Switch Administration, log entry filters.
For example, to display log entries pertaining to all faults, type.
-> show /SP/logs/event/list Class==Fault
Note - If you want to display log entries pertaining to only component failure, use the show /SP/logs/event/list Class==Fault Type==Fault command.
The Oracle ILOM targets of the faulty components follow the word component. For example:
-> show /SP/logs/event/list Class==Fault Event ID Date/Time Class Type Severity ----- ------------------------ -------- -------- -------- 18820 Tue Sep 25 13:44:56 2012 Fault Fault critical Fault detected at time = Tue Sep 25 13:44:56 2012. The suspect component: /SYS/PSU0 has fault.chassis.device.psu.fail with probability=100. Refer to http://support.oracle.com/msg/DCSIB-8000-23 for details. 18569 Tue Sep 18 16:43:13 2012 Fault Repair minor Component /SYS/PSU0 repaired 18567 Tue Sep 18 15:51:48 2012 Fault Fault critical Fault detected at time = Tue Sep 18 15:51:48 2012. The suspect component: /SYS/PSU0 has fault.chassis.device.psu.fail with probability=100. Refer to http://support.oracle.com/msg/DCSIB-8000-23 for details. . . . ->
Note - The most recent events are listed at the top of the log.
In this example, Event ID 18567 on September 18, at 15:51, indicated that a critical fault occurred in the component with Oracle ILOM target /SYS/PSU0. This is power supply 0 as identified in Clearable Fault Targets. Following the Oracle ILOM target is the reason for the fault. A URL is provided for more information about the fault.
Moving up the output, Event ID 18569 on September 18, at 16:43, indicated that a repair action was taken on the component with Oracle ILOM target /SYS/PSU0. The power supply was repaired. The term repaired can mean either repaired or replaced. In either case, the power supply in slot 0 was now functional.
Continuing up the output, Event ID 18820 on September 25 indicated that a critical fault occurred again in the component with Oracle ILOM target /SYS/PSU0.
See Clearable Fault Targets for servicing links.
