Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Tests Subnet Manager configuration.
smconfigtest [spine|leaf][-l][-h]
This hardware command tests the Subnet Manager configuration and reports if it is corrupt.
The smconfigtest command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the smconfigtest command and their purposes.
This example shows how to test the Subnet Manager configuration (priority is 6) with the smconfigtest command.
FabMan@switch_name->smconfigtest leaf smconfigtest:ERROR: /etc/opensm/opensm.conf file has illegal sm_priority : 6 , please change to 5 SubnetManager configuration is invalid for leaf switch. FabMan@switch_name->
