Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Inspect the Power Supply Hardware
Inspect the Power Supply Connectors
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
You must determine which power supply is faulty before you replace it.
See Check Power Supply Status LEDs.
If a power supply is faulty, replace it. See Remove a Power Supply.
-> show -d targets /SP/faultmgmt
If a power supply is faulty, you will see /SYS/PSUx listed in the output under Target:, where x is 0 (left power supply) or 1 (right power supply).
For example:
-> show -d targets /SP/faultmgmt /SP/faultmgmt Targets: 0 (/SYS/PSU0) ->
If a FRU value in addition to or different from /SYS/PSUx is displayed, see Clearable Fault Targets to identify which component is faulty.
In no Oracle ILOM targets are listed, go to Step 5.
