Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Enables a connector or switch chip port.
enableswitchport [--automatic|--reason=reason] connector|Switch port
where:
reason is the reason for disabling the port, Blacklist or Partition.
connector is the number of the QSFP connector (0A to 17B).
port is the number of the port (1 to 36).
This hardware command enables a QSFP connector and port on the switch chip. The command addresses either the connector or the port on the switch chip.
The --reason option enables you to use the Blacklist or Partition passphrases to unlock the state of the port as locked using the disableswitchport command.
The enableswitchport command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the enableswitchport command and their purposes.
This example shows how to enable and de-blacklist connector 1A with the enableswitchport command.
FabMan@switch_name->enableswitchport --reason=Blacklist 1A Enable connector 1A Switch port 22 Adminstate:......................Enabled LinkWidthEnabled:................1X or 4X LinkWidthSupported:..............1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkState:.......................Down PhysLinkState:...................PortConfigurationTraining LinkSpeedActive:.................2.5 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps NeighborMTU:.....................4096 OperVLs:.........................VL0-7 FabMan@switch_name->
