Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Sets monitoring of the Subnet Manager.
setmsmlocationmonitor state|list [-h]
where state is either enable or disable.
This hardware command sets the state of monitoring the location and condition of the primary (or Master) Subnet Manager for the InfiniBand fabric. You can set the state of monitoring to either enabled or disabled. When enabled, information about the MSM is displayed in the user interface.
Note - If the monitor is located on a spine switch and the MSM is on another spine switch, the MSM might not be reachable through LID routed path. This situation gives the false impression in the user interface that there is no MSM in the fabric. Under these conditions, disable MSM monitoring
The list option displays the current state of monitoring.
The setmsmlocationmonitor command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to display the state of the Subnet Manager monitor with the setmsmlocationmonitor command.
FabMan@switch_name->setmsmlocationmonitor list Current state of Master Subnet Manager monitioring: enable FabMan@switch_name->
