Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays switch version.
version
This hardware command shows the hardware and software versions, and date information for the switch and management controller.�
The version command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the version information with the version command.
FabMan@switch_name->version SUN DCS 36p version: 2.1.2-1 Build time: Dec 7 2012 09:33:54 SP board info: Manufacturing Date: 2009.02.20 Serial Number: "NCD2T0307" Hardware Revision: 0x0100 Firmware Revision: 0x0102 BIOS version: NOW1R112 BIOS date: 04/24/2009 FabMan@switch_name->
Switch Administration, displaying firmware version
