Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
The InfiniBand commands act upon or monitor many aspects of the InfiniBand fabric. The commands are available through the Oracle ILOM CLI interface with the /SYS/Switch_Diag and /SYS/Fabric_Mgmt targets. See Linux Shells for InfiniBand Commands.
With the standard Linux shell CLI interface, only the root user of the management controller can run all of the InfiniBand commands. The format of the InfiniBand commands is typically as follows:
FabMan@switch_name->command [option] [option] ...
