Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays environmental status.
env_test
This hardware command performs a series of hardware and environmental tests of the switch. This command is an amalgamation of these commands:
checkpower
checkvoltages
showtemps
getfanspeed
connector
checkboot
The command output provides voltage and temperature values, pass-fail results, and error messages.
The env_test command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the hardware and environmental status of the switch with the env_test command.
FabMan@switch_name->env_test Environment test started: Starting Environment Daemon test: Environment daemon running Environment Daemon test returned OK Starting Voltage test: Voltage ECB OK Measured 3.3V Main = 3.28 V Measured 3.3V Standby = 3.37 V Measured 12V = 12.06 V Measured 5V = 5.03 V Measured VBAT = 3.25 V Measured 2.5V = 2.49 V Measured 1.8V = 1.78 V Measured I4 1.2V = 1.22 V Voltage test returned OK Starting PSU test: PSU 0 present PSU 1 present PSU test returned OK Starting Temperature test: Back temperature 28 Front temperature 28 SP temperature 42 Switch temperature 32, maxtemperature 32 Temperature test returned OK Starting FAN test: Fan 0 not present Fan 1 running at rpm 11881 Fan 2 running at rpm 11663 Fan 3 running at rpm 11881 Fan 4 not present FAN test returned OK Starting Connector test: Connector test returned OK Starting Onboard ibdevice test: Switch OK All Internal ibdevices OK Onboard ibdevice test returned OK Starting SSD test: SSD test returned OK Environment test PASSED FabMan@switch_name->
