Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Provides help with Oracle ILOM commands.
help [-o terse|verbose][command|legal|targets|target|target property]
where:
command is the Oracle ILOM command for which you are seeking help.
target is the target for which you are seeking help.
property is the property of the target for which you are seeking help.
This Oracle ILOM command gives information and assistance about commands and targets. The -o option enables either terse or verbose output. The help targets command displays a basic list of targets. The help legal command displays the legal notice.
This example shows how to display verbose help about the exit command with the help command.
-> help -o verbose exit The exit command is used to terminate a session. Usage: exit Example: -> exit Connection to nyc-sp closed. ->
Switch Reference, help command
