Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Remove the Switch From the Rack
You must determine if the battery is faulty before you replace it.
-> show -d targets /SP/faultmgmt
If the battery is faulty, you will see /SYS/MB listed in the output under Target:.
For example:
-> show -d targets /SP/faultmgmt /SP/faultmgmt Targets: 0 (/SYS/MB) ->
-> show -d properties /SP/faultmgmt/number/faults/0
where number is the number to the left of /SYS/MB. For example:
-> show -d properties /SP/faultmgmt/0/faults/0 /SP/faultmgmt/0/faults/0 Properties: class = fault.chassis.device.battery.low sunw-msg-id = DCSIB-8000-45 uuid = 82e90599-8650-47dc-b613-1e602607441b timestamp = 2002-01-01/00:07:27 fru_part_number = 3002234 fru_serial_number = 006541 product_serial_number = AK00022680 chassis_serial_number = AK00022680 ->
If the battery is faulty, replace it. See Replace the Battery.
If you do not see the word battery, or if a FRU value in addition to or different from /SYS/MB is displayed in Step a, see Clearable Fault Targets to identify which component is faulty.
If no Oracle ILOM targets are listed in Step a, go to Step 4.
-> show /SYS/MB/V_BAT value /SYS/MB/V_BAT Properties: value = 3.136 Volts ->
