Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Reads QSFP cable information.
connector connector present|portstate|info|dump [-h]
where connector is the name of the connector (0A to 17A and 0B to 17B).
This hardware command performs a pass-fail test to verify that an InfiniBand cable is connected to a particular connector and to the switch chip port that the link routes. The command can also read the data registers of the cable and report FRU ID information.
The connector command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the connector command and their purposes.
This example shows how to display the FRU ID information for connector 1A with the connector command.
FabMan@switch_name->connector 1A info Cable connector 1A present Indentifier: QSFP Connector type: Copper pigtail Vendor: Amphenol Vendor OUI: 415048 Partnumber: 568400005 Revision: C Serialnumber: APF08510050019 Date: 081219 FabMan@switch_name->
