Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Queries InfiniBand port counters.
perfquery [-d][-e][-G][-h][-a][-l][-r][-R][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|guid [[port][reset_mask]]]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
guid is the global unique identifier.
port is the port being queried.
reset_mask is the two-byte mask.
This InfiniBand command uses the performance management GMPs to acquire the PortCounters or PortExtendedCounters from the Performance Manager agent at the node or port specified.
Note - The data values retrieved from PortCounters and PortExtendedCounters are represented as octets divided by 4.
Note - Providing a port value of 255 ensures that the operation is performed on all ports.
The perfquery command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the perfquery command and their purposes.
This example shows how to display all port counters for LID 15, port 23 with the perfquery command.
FabMan@switch_name->perfquery 1 22 # Port counters: Lid 1 port 22 PortSelect:......................22 CounterSelect:...................0x1b01 SymbolErrors:....................0 LinkRecovers:....................0 LinkDowned:......................0 RcvErrors:.......................0 RcvRemotePhysErrors:.............0 RcvSwRelayErrors:................0 XmtDiscards:.....................0 XmtConstraintErrors:.............0 RcvConstraintErrors:.............0 LinkIntegrityErrors:.............0 ExcBufOverrunErrors:.............0 VL15Dropped:.....................0 XmtData:.........................20232 RcvData:.........................20232 XmtPkts:.........................281 RcvPkts:.........................281 FabMan@switch_name->
perfquery man page
