Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays the Subnet Manager log.
showsmlog [-h]
This hardware command first displays the parameters of the Subnet Manager configuration file, and then the chronological log entries for the Subnet Manager within the management controller. Tapping the space bar displays the next screen of the log. Pressing the Q key quits. The -h option provides help.
The showsmlog command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the Subnet Manager log with the showsmlog command.
Note - The output of the example is a very small portion and will differ from your output.
FabMan@switch_name->showsmlog Jan 02 03:16:57 079794 [B7EE66C0] 0x03 -> OpenSM 3.2.6_20120116 - Oracle patch 10.5.2 ------------------------------------------------- OpenSM 3.2.6_20120116 - Oracle patch 10.5.2 Reading Cached Option File: /etc/opensm/opensm.conf Loading Cached Option: partition_config_file = /conf/partitions.conf Loading Cached Option: no_partition_enforcement = TRUE Loading Cached Option: routing_engine = ftree . . . Dec 10 03:39:04 019624 [B669FB90] 0x02 -> SUBNET UP Dec 10 03:39:04 035624 [B669FB90] 0x02 -> Fabric has 1 switches - topology is not fat-tree. Falling back to default routing Dec 10 03:39:04 035624 [B669FB90] 0x01 -> ucast_mgr_route: ftree: cannot build lid matrices. (END) FabMan@switch_name->
