Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays links presence.
listlinkup [link][peer][internal|all|connected]
This hardware command lists the presence of links and the up-down state of the associated ports on the switch chip.� The listlinkup command also accepts these arguments:
link – Displays additional information about the links.
peer – Displays additional information about the peer ports.
internal – Displays only internal links.
all – Displays all link types.
connected – Displays only links that are connected to other nodes.
The listlinkup command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display comprehensive information about all link presence, associated ports, link state, and information about the peers with the listlinkup command.
FabMan@switch_name->listlinkup link peer all Connector 0A Not present Connector 1A Present <-> Switch Port 22 is up (Enabled) Peer: "SUN DCS 36P QDR techpubs 10.132.124.33" Peerport: 8 NodeGUID: 0x0021283a8980a0a0 LID: 0x0001 Connector 2A Not present Connector 3A Not present Connector 4A Not present Connector 5A Not present Connector 6A Not present Connector 7A Present <-> Switch Port 33 is up (Enabled) Peer: "SUN DCS 36P QDR techpubs 10.132.124.33" Peerport: 34 NodeGUID: 0x0021283a8980a0a0 LID: 0x0001 Connector 8A Not present Connector 9A Present <-> Switch Port 14 is up (Enabled) Peer: "SUN DCS 36P QDR techpubs 10.132.124.33" Peerport: 29 NodeGUID: 0x0021283a8980a0a0 LID: 0x0001 Connector 10A Not present Connector 11A Not present Connector 12A Not present Connector 13A Not present Connector 14A Not present Connector 15A Not present Connector 16A Not present Connector 17A Not present Connector 0B Not present Connector 1B Not present Connector 2B Not present Connector 3B Not present Connector 4B Not present Connector 5B Present <-> Switch Port 29 is up (Enabled) Peer: "SUN DCS 36P QDR techpubs 10.132.124.33" Peerport: 14 NodeGUID: 0x0021283a8980a0a0 LID: 0x0001 Connector 6B Not present Connector 7B Present <-> Switch Port 34 is up (Enabled) Peer: "SUN DCS 36P QDR techpubs 10.132.124.33" Peerport: 33 NodeGUID: 0x0021283a8980a0a0 LID: 0x0001 Connector 8B Not present Connector 9B Not present Connector 10B Not present Connector 11B Not present Connector 12B Not present Connector 13B Not present Connector 14B Present <-> Switch Port 08 is up (Enabled) Peer: "SUN DCS 36P QDR techpubs 10.132.124.33" Peerport: 22 NodeGUID: 0x0021283a8980a0a0 LID: 0x0001 Connector 15B Not present Connector 16B Not present Connector 17B Not present FabMan@switch_name->
