Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Check NET MGT Port Status LEDs
Check Power Supply Status LEDs
Display Faulty Components (fault_state)
Display Faulty Components (/SP/faultmgmt)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Display the General Alarm State of Systems and Components
Oracle ILOM Target Alarm States
Determine Oracle ILOM Sensor Target Types
Evaluating a Voltage Sensor Alarm
Evaluating a Temperature Sensor Alarm
Evaluating a Speed Sensor Alarm
Evaluating a State Sensor Alarm
Evaluating a Presence Sensor Alarm
Presence Sensor Alarm Conditions
Access the Oracle ILOM CLI (NET MGT Port)
Enter the Restricted Linux Shell
Exit the Restricted Linux Shell
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
-> show / -a -l 4 -o table alarm_status Target | Property | Value --------------------+------------------------+---------- /SYS/MB/V_ECB | alarm_status | cleared /SYS/MB/V_3.3VMain | alarm_status | cleared /SYS/MB/ | alarm_status | cleared V_3.3VMainOK | | /SYS/MB/V_3.3VStby | alarm_status | minor . . . /SYS/FAN3/PRSNT | alarm_status | cleared /SYS/FAN3/TACH | alarm_status | cleared /SYS/FAN3/FAULT | alarm_status | cleared ->
For example, minor. For more information about alarm states, see Oracle ILOM Target Alarm States.
For example, /SYS/MB/V_3.3VStby.
-> show target value
where target is the Oracle ILOM target for the sensor from Step 4. For example:
-> show /SYS/MB/V_3.3VStby value /SYS/MB/V_3.3VStby Properties: value = 3.490 Volts ->
For example, /SYS/MB/V_3.3VStby and 3.490 volts.
