Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Fan Events
The following table lists fan events.
Messages and Descriptions
Description
SNMP Trap Message: sunHwTrapFanSpeedCritThresholdExceeded
Oracle ILOM Event Message: Lower critical threshold exceeded
Severity and Description: Major; A fan speed sensor has reported that its value has gone above an upper critical threshold setting or below a lower critical threshold setting.
The sunHwTrapThresholdType object indicates whether the threshold was an upper or lower threshold.
/SYS/MB/FM[0-3]/F[0-1]/TACH
SNMP Trap Message: sunHwTrapFanSpeedCritThresholdDeasserted
Oracle ILOM Event Message: Lower critical threshold no longer exceeded
Severity and Description: Informational; A fan speed sensor has reported that its value has gone below an upper critical threshold setting or above a lower critical threshold setting.
SNMP Trap Message: sunHwTrapFanSpeedFatalThresholdExceeded
Oracle ILOM Event Message: Lower fatal threshold exceeded
Severity and Description: Critical; A fan speed sensor has reported that its value has gone above an upper fatal threshold setting or below a lower fatal threshold setting.
SNMP Trap Message: sunHwTrapFanSpeedFatalThresholdDeasserted
Oracle ILOM Event Message: Lower fatal threshold no longer exceeded
Severity and Description: Informational; A fan speed sensor has reported that its value has gone below an upper fatal threshold setting or above a lower fatal threshold setting.
Related Information
