Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Install a PCIe Card in PCIe Slot 1 or 2
Note -  PCIe slot 1 is nonfunctional in single-processor systems.
  1. Retrieve the PCIe card and riser you want to install.
  2. Insert the rear bracket that is attached to the PCIe card into the PCIe riser.
  3. Hold the riser in one hand and use your other hand to carefully insert the PCIe card connector into the Riser.
    image:Figure showing how to install a PCIe card in to slots 1 and 2.
  4. Install the PCIe riser into the server.
    For instructions, see Install a PCIe Riser Into PCIe Slot 1 or 2.
