Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Use the Oracle ILOM Web Interface for Immediate Shutdown
Caution
Caution  -  An immediate power down might corrupt system data, so only use this procedure to power down the server after attempting the graceful power down procedure.
  1. Log in to the Oracle ILOM web interface using an Administrator account.
    The Oracle ILOM web interface System Information page appears.
  2. In the left pane, click Host Management → Power Control, and select Immediate Power Off in the Select Action list.
  3. Click Save, then click OK.
    The server powers down immediately.
  4. Disconnect the power and data cables from the server.
    See Disconnect Cables From the Server.
    Caution
    Caution  -  When the server is powered down, it enters standby power mode In standby power mode, power is still directed to the service processor remote management subsystem and power supply fans. To completely power off the server, you must disconnect the power cords from the power supplies.
Related Information
