Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
USB Ports
The server has six USB ports for attaching supported USB 2.0-compliant devices. There are two USB ports on the server front panel, two on the rear panel, and two on the motherboard.
image:Figure showing the USB ports. Table 24  USB Port Signals
Pin
Signal Description
1
+5 V
2
DAT-
3
DAT+
4
Ground
Related Information
