Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Remove a PCIe Card From PCIe Slot 3
  1. Remove the PCIe riser from the server.
    For instructions, see Remove the PCIe Riser From PCIe Slots 3 and 4.
  2. Remove the PCIe card from the riser.
    1. Hold the riser in one hand and use your other hand to carefully remove the PCIe card connector from the riser.
    2. Disconnect the rear bracket attached to the PCIe card from the rear of the PCIe riser.
      image:Figure showing how to remove a PCIe card form slot 3.
  3. Place the PCIe card on an antistatic mat.
    Caution
    Caution  -  Whenever you remove a PCIe card, you should replace it with another PCIe card or a PCIe filler panel. Installing PCIe filler panels in vacant PCIe slots helps reduce the level of electromagnetic interference (EMI) emitted by the server. For instructions for installing PCIe filler panels, see Removing and Installing Server Filler Panels.
