Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Assign Serial Port Output Using the CLI
  1. Open an SSH session and at the command line log in to the SP Oracle ILOM CLI.
    Log in as a user with root or administrator privileges. For example:
    ssh root@ipadress
    Where ipadress is the IP address of the server module SP.
    For more information, refer to Accessing Oracle ILOM in the Oracle X5 Series Servers Administration Guide.
    The Oracle ILOM CLI prompt (->) appears.
  2. To set the serial port owner, type:
    -> set /SP/serial/portsharing /owner=host
    Note -  The serial port sharing value by default is owner=SP.
  3. Connect a serial host to the server.
