Serial Management
Port
The serial management
connector (labeled
SER MGT) is an RJ-45 connector
that can be accessed from the rear panel. This port is the default
connection to the server. Use this port only for
server management.
Table 19 Default Serial Connections for Serial Port
Connector |
SER MGT |
Rate |
9600 baud |
Parity |
None |
Stop bits |
1 |
Data bits |
8 |
The following figure and table describe the SER MGT port pin
signals.
Table 20 Serial Management Port Signals
1 |
5 |
Ground |
2 |
Data Terminal Ready |
6 |
Receive Data |
3 |
Transmit Data |
7 |
Data Set Ready |
4 |
Ground |
8 |
Clear to Send |
If you need to connect to the SER MGT port using a cable with
either a DB-9 or a DB-25 connector, follow the pin descriptions
in the tables to create a crossover adapter appropriate for your
serial connection.
Table 21 RJ-45 to DB-9 Adapter Crossover Wiring Reference
1 |
8 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
2 |
RXD |
4 |
Signal Ground |
5 |
Signal Ground |
5 |
Signal Ground |
5 |
Signal Ground |
6 |
RXD |
3 |
TXD |
7 |
DSR |
4 |
DTR |
8 |
CTS |
7 |
RTS |
Table 22 RJ-45 to DB-25 Adapter Crossover Wiring Reference
1 |
5 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
3 |
RXD |
4 |
Signal Ground |
7 |
Signal Ground |
5 |
Signal Ground |
7 |
Signal Ground |
6 |
RXD |
2 |
TXD |
7 |
DSR |
20 |
DTR |
8 |
CTS |
4 |
RTS |
