A key benefit of using Oracle ILOM CLI from IPMItool is that the CLI commands can be scripted and then the script can be run on multiple SP instances. Scripting is possible because the CLI commands can be included on the IPMItool command line where each argument on the command line is treated as a separate Oracle ILOM CLI command. Command separation is archived by including quotation marks at the beginning and end of each Oracle ILOM CLI command.
The following example shows how to include two CLI commands on the IPMItool command line. In the example, notice that each command begins and ends with quotation marks.
# ipmitool -H SP_hostname_or_IPaddress -U username -P password sunoem cli
“show /SP/services” “show /SP/logs”
Connected. Use ^D to exit.
-> show /SP/services
/SP/services
Targets:
http
https
ipmi
kvms
servicetag
snmp
ssh
sso
Properties:
Commands:
cd
show
-> show /SP/logs
/SP/logs
Targets:
audit
event
Properties:
Commands:
cd
show
-> Session closed
Disconnected
