Before You Begin
To generate configured email notification alerts, you must enable the Oracle ILOM client to act as an SMTP client to send the email alert messages. To enable the Oracle ILOM client as an SMTP client, you must specify the IP address and port number of an outgoing SMTP email server that will process the email notifications.
Prior to enabling the Oracle ILOM client as an SMTP client, gather the IP address and port number of the outgoing SMTP email server.
You can use the get and set commands to configure the SMTP client. For a description of the MIB objects used in this procedure, see Valid SMTP Client MIB Objects and the SUN-ILOM-CONTROL-MIB.
To configure SMTP Client properties in Oracle ILOM:
ssh username@snmp_manager_ip_address
Password: password
% snmpget SNMP_agent ilomCtrlSMTPEnabled.0
% snmpset SNMP_agent ilomCtrlSMTPEnabled.0 i 1
% snmpget SNMP_agent ilomCtrlSMTPServerIP.0
% snmpset SNMP_agent ilomCtrlSMTPServerIP.0 s ip_address
% snmpget SNMP_agent ilomCtrlSMTPPortNumber.0
% snmpset SNMP_agent ilomCtrlSMTPPortNumber.0 i 25
% snmpget SNMP_agent ilomCtrlSMTPCustomSender.0
% snmpset SNMP_agent ilomCtrlSMTPCustomSender.0 s ???ilom-alert@HOSTNAME.abc.com'
The following table describes the SMTP Email Alert Notification SNMP MIB objects.
