Manage the System Power Policy
Note -
The settings defined in this procedure are not applicable to all server platforms.
Note -
The IPMI TLS interface (
orcltls) is supported as of Oracle ILOM
firmware version 3.2.8 and later. For a higher level of security, you should always specify
the IPMI TLS interface (
-I orcltls) when executing Oracle ILOM commands
from the IMPItool utility. For more information about the IPMI TLS interface that is provided
by Oracle, see
IPMI TLS Service and Interface.
To get the current system power policy, type:
$ipmitool -I [orcltls|lanplus] -H SP_hostname_or_IPaddress -U username -P password
raw 0x2e 0x43 4
To set the power manage policy to performance, type
$ ipmitool -I [orcltls|lanplus] -H SP_hostname_or_IPaddress -U username -P password
raw 0x2e 0x42 2 00 00 00 00
To set the power manage policy to elastic, type:
raw 0x2e 0x42 2 00 00 00 01
To set the power manage policy to disabled, type:
raw 0x2e 0x42 2 00 00 00 02
The following table describes the Power Management Policy State (IPMItool) input fields:
Input Data
1
Sunoem command group number: 0x2e.
2
Command code 0x42 sets the Power Policy Activation State.
3
Group extension identification: 2.
4-6
Reserved fields.
7
Sub-commands for power policy activation: 00 - Performance policy 01 - Elastic policy 02 - Disable the policy
