Manage SPARC Host Boot Mode Properties
Note -
You can use the get and set commands to view and configure SPARC boot mode settings. For a description of the MIB objects used in these commands, see the SUN-ILOM-CONTROL-MIB.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ipaddress
Password: password
Refer to the following SNMP command examples:
To view the boot mode state for the host, type:
% snmpget SNMP_agent ilomCtrlSPARCBootModeState.0
To configure the host to retain current NVRAM variable settings, type:
% snmpset SNMP_agent ilomCtrlSPARCBootModeState.0 i 1
To view the boot script to use when the boot mode state is set to script, type:
% snmpget SNMP_agent ilomCtrlSPARCBootModeScript.0
To specify the boot script to use when the boot mode state is set to ???setenv diag-switch', type:
ilomCtrlSPARCBootModeScript.0 s ???setenv diag-switch'
To view date and time when the boot mode configuration will expire, type:
% snmpget SNMP_agent ilomCtrlSPARCBootModeExpires.0
To view the string that refers to the LDOM configuration name, type:
% snmpget SNMP_agent ilomCtrlSPARCBootModeLDOMConfig.0
To set the LDOM configuration name to default, type:
% snmpset SNMP_agent ilomCtrlSPARCBootModeLDOMConfig.0 s default
