Manage Email Alert Settings
Note -
You can use the get and set commands to view and configure email alert settings. For a description of the MIB objects used in these commands, see the SUN-ILOM-CONTROL-MIB.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ipaddress
Password: password
Refer to the following SNMP command examples:
To view the optional format used to identify the sender or the “from” address, type:
% snmpget SNMP_agent ilomCtrlAlertEmailCustomSender.0
To set the optional format used to identify the sender or the “from” address, type:
% snmpset SNMP_agent
ilomCtrlAlertEmailCustomSender.0 s
???ilom-alert@HOSTNAME.abc.com'
To view an optional string that can be added to the beginning of the message body, type:
% snmpget SNMP_agent ilomCtrlAlertEmailMessagePrefix.0
To define an optional string (for example: BeginMessage) that can be added to the beginning of the message body, type:
% snmpset SNMP_agent ilomCtrlAlertEmailMessagePrefix.0 s
???BeginMessage'
