View and Set Clock Settings
Note -
You can use the
get and
set commands to view and set clock settings with respect to
Network Time Protocol (NTP) synchronization. For a description of valid MIB objects for this procedure, see the table following this procedure.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ip_address
Password: password
Refer to the following SNMP commands for examples:
To view the NTP server state, type:
% snmpget SNMP_agent ilomCtrlNTPEnabled.0
To set the NTP server state to enabled, type:
% snmpset SNMP_agent ilomCtrlNTPEnabled.0 i 1
To view the date and time of the device, type:
% snmpget SNMP_agent ilomCtrlDateAndTime.0
To set the date and time of the device, type:
% snmpset SNMP_agent ilomCtrlDateAndTime.0 s 2013-3-24,4:59:47.0
The following table describes the valid SNMP MIB objects for Oracle ILOM clock properties.
ilomCtrlDateAndTime
The date and time of the device.
date/time
String
None
ilomCtrlNTP
Enabled
Specifies whether the Network Time Protocol is enabled.
true(1),
false(2)
Integer
false
ilomCtrlTimezone
The configured time zone string.
Size: 0 to 255
String
None
