Manage SPARC Host Keyswitch Property
Note -
You can use the get and set commands to view and configure SPARC key switch settings. For a description of the MIB objects used in these commands, see the SUN-ILOM-CONTROL-MIB.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ipaddress
Password: password
Refer to the following SNMP command examples:
