Configure Severity Level Alert Rule
Note -
You can use the
get and
set commands to view and
configure alert rule configurations. For a description of valid MIB objects for this procedure, see the table following this procedure.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ip_address
Password: password
To view the severity level for the alert rule with an alert ID of 2, type:
% snmpget SNMP_agent ilomCtrlAlertSeverity.2
To set the severity level to critical for the alert rule with an alert ID of 2, type:
% snmpset SNMP_agent ilomCtrlAlertSeverity.2 i 2
The following table describes the Alert Rule Severity Level SNMP MIB objects.
ilomCtrlAlert ID
An integer ID associated with a given alert rule.
Note -
This object is not accessible.
Range: 0 to 65535
Integer
None
ilomCtrlAlert Severity
Specifies the mininum event severity that should trigger an alert for a given class.
disable(1),
critical(2),
major(3),
minor(4),
down(5)
Integer
None
ilomCtrlAlert Type
Specifies the type of notification for a given alert. If the type is snmptrap(2) or ipmipet(3), the ilomCtrlAlertDestinationIP must be specified. If the type is email(1), the ilomCtrlAlert DestinationEmail must be specified.
email(1)
snmptrap(2)
ipmipet(3)
Integer
None
ilomCtrlAlert DestinationIP
Specifies the IP address to send alert notifications to when the alert type is snmptrap(2) or ipmipet(3).
ip_address
String
None
ilomCtrlAlert Destination Email
Specifies the email address to send alert notifications to when the alert type is email(1).
email address
Size: 0 to 255
String
None
ilomCtrlAlert SNMPVersion
Specifies the version of SNMP trap that should be used for the given alert rule.
v1(1),
v2c(2),
v3(3)
Integer
None
ilomCtrlAlert SNMPCommunity OrUsername
Specifies the community string to be used when the ilomCtrlAlertSNMPVersion property is set to v1(1) or v2c(2). Specifies the SNMP user name to use when the ilomCtrlAlertSNMPVersion is set to v3(3).
Size: 0 to 255
String
None
ilomCtrlAlert EmailEvent ClassFilter
A class name or all to filter emailed alerts on.
Size: 0 to 255
String
None
ilomCtrlAlert EmailEventTypeFilter
Size 0 to 255
String
None
