Configure Remote Syslog IP Destinations
Note -
You can use the
get and
set commands to view and set IP addresses for a
remote syslog receiver. For a description of valid MIB objects for this procedure, see the table following this procedure.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ip_address
Password: password
To view a remote syslog destination IP address, type:
% snmpget SNMP_agent ilomCtrlRemoteSyslogDestAddress1.0
To set a remote syslog destination IP address, type:
% snmpset SNMP_agent ilomCtrlRemoteSyslogDestAddress1.0 a ip_address
The following table describes the Syslog IP Destinations SNMP MIB objects.
ilomCtrlRemote SyslogDest1
The IP address of the first remote syslog destination (log host).
ip_address
String
None
ilomCtrlRemote SyslogDest2
The IP address of the second remote syslog destination (log host).
ip_address
String
None
