This is a hot-service procedure that can be performed by a customer while the server is running.
![]() | Caution - Always replace a faulty power supply with a power supply of the same type (model). |
![]() | Caution - Replace the power supply within 5 minutes to ensure proper system cooling. |
Ensure you press the power supply in firmly, then close the latch. You hear an audible click when the power supply fully seats.
For instructions for reconnecting the CMA left-side connectors, refer to Install the Cable Management Arm in SPARC S7-2 Server Installation Guide.
