![]() | Caution - These procedures require that you handle components that are sensitive to static discharge. This sensitivity can cause the component to fail. To avoid damage, ensure that you follow antistatic practices to Prevent ESD Damage. |
![]() | Caution - Ensure that all power is removed from the server before removing or installing an eUSB drive or damage to the drive might occur. You must disconnect all power cables from the system before performing these procedures. |
These topics describe how to service the eUSB drive.
