If the server is installed in a rack with extendable slide rails, use this procedure to extend the server to the maintenance position.
Caution - To reduce the risk of personal injury, stabilize the expansion rack cabinet and extend all anti tilt devices before extending the server from the rack. |
For instructions for stabilizing the rack, see the Stabilize the Rack in SPARC S7-2 Server Installation Guide.
Although the CMA that is supplied with the server is hinged to accommodate extending the server, you should ensure that all cables and cords are capable of extending.
When in an open position, the release latch covers engage the slide rail release latches.
The server is now in the extended maintenance position.
