![]() | Caution - Deploy any rack anti tilt mechanisms before installing the server into the rack. |
![]() | Caution - The server weighs approximately 18.1 kg (40.0 lbs). Two people are required to carry the chassis and install it into the rack. |
The server is now in the extended maintenance position.
As you push the server into the rack, verify that the CMA retracts without binding.
You will hear an audible click when the server is in the normal rack position.
For installation instructions for the CMA, refer to Install the Cable Management Arm in SPARC S7-2 Server Installation Guide.
For instructions on reconnecting cables to the rear of the server, see Reconnect Data Cables and Power Cords.
For detailed information on connecting cables to the rear of the server, refer to Cabling the Server in SPARC S7-2 Server Installation Guide.
