Depending on the nature of the replaced drive, you might need to perform administrative tasks to reinstall software before the server can boot. Refer to the Oracle Solaris OS administration documentation for more information.
# cfgadm -al
This command helps you identify the drive you installed.
Ap_id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c1t0d0 disk connected configured unknown c0::sd1 disk connected unconfigured unknown usb0/1 unknown empty unconfigured ok usb0/2 unknown empty unconfigured ok ...
For example, to configure the second disk c0::sd1, type:
# cfgadm -c configure c0::sd1
Replace c0::sd1 with the drive name for your configuration.
# cfgadm -al
The replacement drive is now listed as configured, as shown in the following example.
Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c1t0d0 disk connected configured unknown c0::dsk/c1t1d0 disk connected configured unknown usb0/1 unknown empty unconfigured ok usb0/2 unknown empty unconfigured ok ...
For additional drive verification, you can run Oracle VTS. Refer to the Oracle VTS documentation for details at http://docs.oracle.com/cd/E19719-01/index.html.
