El switch informa el estado general de enfriamiento para todo el sistema, incluido un inventario de los ventiladores instalados y la temperatura que entra y sale del chasis.
-> show -d properties /System/Cooling /System/Cooling Properties: health = OK health_details = - installed_chassis_fans = 8 max_chassis_fans = 8 installed_power_supply_fans = Not Supported max_power_supply_fans = Not Supported inlet_temp = 33 degrees C exhaust_temp = 38 degrees C ->
