Puede visualizar información sobre el procesador de servicio, incluida información sobre la FRU y los tipos de controladores que están en uso en el procesador de servicio.
-> show -d properties /SYS/SP/OK /SYS/SP/OK Properties: type = Indicator ipmi_name = SP/OK value = On ->
/SYS/SP
Properties:
type = Service Processor
ipmi_name = SP
fru_description = PCA,PILOT3 SP, OPUS
fru_manufacturer = Oracle Corporation
fru_part_number = 7096151
fru_rev_level = 04
fru_serial_number = 489089M+14516P002F
fault_state = OK
clear_fault_action = (none)
-> show -d properties /SP/
/SP/
Properties:
check_physical_presence = true
current_hostname = techpubs
hostname = techpubs
reset_to_defaults = all
system_contact = matlock
system_description = unknown, ILOM v3.2.6.0, r108582
system_identifier = leaf
system_location = SCA21-lab
-> show -d properties /SP/config /SP/config Properties: dump_uri = (Cannot show property) include_faultdata = false load_uri = (Cannot show property) passphrase = (none) ->
