Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Ethernet Splitter Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Service
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showgwconfig Command
showgwports Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
SUN-DCS-IB-MIB MIB OID Command Syntax
Enclosure OIDs
Enclosure Nodes OIDs
Neighbor Node OIDs
Subnet Manager Info OIDs
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Port Counters Table OIDs
PMA Extended Port Counters Table OIDs
Understanding SNMP Trap OIDs
Trap Control OIDs
Trap Threshold OIDs
Trap Notification OIDs
Understanding Gateway Specific OIDs
Gateway Port Status OIDS
Gateway Port Counter OIDS
SUN-FABRIC-MIB MIB OID Command Syntax
Fabric Element OIDs
Fabric Management OIDs
Fabric Management Element OIDs
Fabric Management External Element OIDs
Fabric Management Gateway OIDs
Fabric Management Link OIDs
Fabric Trap OIDs
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
NTP OIDs
Remote Syslog OIDs
HTTP OIDs
HTTPS OIDs
Network OIDs
User OIDs
Session OIDs
Event Log OIDs
Alert OIDs
Clock OIDs
Backup and Restore OIDs
Identification OIDs
SMTP OIDs
DNS OIDs
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
High-Level OIDs
NIM Equipment Table OIDs
Physical Class Extension Table OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Discrete Sensor Table OIDs
Sun Platform Fan Table OIDs
Sun Platform Alarm Table OIDs
Understanding the ENTITY-MIB MIB OIDs
ENTITY-MIB MIB OID Command Syntax
Physical Entity Table OIDs
Index
This table lists SMA object identifiers supported by the SUN-DCS-IB-MIB MIB.
Description of Task or Activity
Action
MIB OID
Display a table of SMA PortInfo information.
read
ibSmaPortInfoTable
Display a row of the ibSmaPortInfoTable.
read
ibSmaPortInfoEntry
Display an index of SMA InfiniBand nodes.
read
ibSmaNodeIndex
Display an index of SMA InfiniBand data ports.
read
ibSmaPortIndex
Display SMA enabled link width.
read
ibSmaPortLinkWidthEnabled
Display SMA supported link width.
read
ibSmaPortLinkWidthSupported
Display SMA currently active link width.
read
ibSmaPortLinkWidthActive
Display SMA supported link speed.
read
ibSmaPortLinkSpeedSupported
Display the SMA link state of the port.
read
ibSmaPortLinkState
Display the SMA physical state of the port.
read
ibSmaPortPhysState
Display the SMA LinkDownDefault state.
read
ibSmaPortLinkDownDefaultState
Display the SMA LID mask control count for multipath support of CA and router ports.
read
ibSmaPortLidMaskCount
Display the currently active SMA link speed.
read
ibSmaPortLinkSpeedActive
Display the enabled SMA link speed.
read
ibSmaPortLinkSpeedEnabled
Display the active maximum MTU enabled on the SMA port for transmit.
read
ibSmaPortNeighborMtu
Display the virtual lane configuration supported on the SMA port.
read
ibSmaPortVirtLaneSupport
Display the number of high priority packets that are transmitted before a low priority packet is sent.
read
ibSmaPortVlHighPriorityLimit
Display the number of virtual lane - weight pairs supported on the SMA port in the ibSmaHiPriVlArbTable for high priority.
read
ibSmaPortVlArbHighCapacity
Display the number of virtual lane - weight pairs supported on the SMA port in the ibSmaHiPriVlArbTable for low priority.
read
ibSmaPortVlArbLowCapacity
Display the maximum MTU supported by the SMA port.
read
ibSmaPortMtuCapacity
Display or specify the number of sequential packets dropped that causes the SMA port to enter the VLStalled state.
read
ibSmaPortVlStallCount
Display or specify the time a packet can live at the head of a virtual lane queue.
read
ibSmaPortHeadOfQueueLife
Display the virtual lanes operational on the SMA port.
read
ibSmaPortOperationalVls
Display support of optional inbound partition enforcement.
read
ibSmaPortPartEnforceInbound
Display support of optional outbound partition enforcement.
read
ibSmaPortPartEnforceOutbound
Display support of optional inbound raw packet enforcement.
read
ibSmaPortFilterRawPktInbound
Display support of optional outbound raw packet enforcement.
read
ibSmaPortFilterRawPktOutbound
Display the local physical error threshold value. When the threshold is exceeded, a local link integrity error is determined.
read
ibSmaPortLocalPhysErrorThreshold
Display overrun error threshold value. When the number of buffer overruns exceeds the threshold, an excessive buffer overrun error is determined.
read
ibSmaPortOverrunErrorThreshold
Display a mapping of an InfiniBand device SMA port to connector.
read
ibSmaPortConnectorPosition
Related Information
