Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Oracle ILOM Targets and Descriptions
Oracle ILOM General System Targets and Properties
Oracle ILOM Indicator Targets and Properties
Oracle ILOM Power Supply Targets and Properties
Oracle ILOM Temperature Targets and Properties
Oracle ILOM Voltage Targets and Properties
Oracle ILOM General Targets and Properties
Oracle ILOM Service Targets and Properties
Oracle ILOM User and Session Targets and Properties
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
This table lists the Oracle ILOM /SYS/FANx targets and their properties. Targets without properties are not listed.
Note - The /SYS/FANx target is only available for currently present fans.
