Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
V1 and V2c Protocol Command Format
Display the Date and Time (SNMP)
Display the Aggregate Sensors State (SNMP)
Display Power Supply Status (SNMP)
Display Internal Temperatures (SNMP)
Display the Sensor Alarm State (SNMP)
Display Oracle ILOM Sessions (SNMP)
Display the Oracle ILOM Event Log (SNMP)
Checking the Status of Services (SNMP)
Display the HTTP Service Status (SNMP)
Display the HTTPS Service Status (SNMP)
Display the DNS Client Status (SNMP)
Display the SMTP Client Status (SNMP)
Display the NTP Servers (SNMP)
Verifying Other Aspects With Oracle ILOM (SNMP)
Display the Alert Properties (SNMP)
Display Oracle ILOM User Accounts (SNMP)
Display the Remote Log Hosts (SNMP)
Display the Network Management Configuration (SNMP)
Display Power Supply FRU ID (SNMP)
Display the System Components (SNMP)
Display the Additional System Component Information (SNMP)
Display the Firmware Version (SNMP)
Display System Identification Properties (SNMP)
Performing General Tasks (SNMP)
Set the Network Time Protocol State (SNMP)
Set the Network Time Protocol Servers (SNMP)
Clear the Oracle ILOM Event Log (SNMP)
Set the Remote Log Hosts (SNMP)
Configure the DNS Client (SNMP)
Configure the SMTP Client (SNMP)
Set the Network Parameters (SNMP)
Set the System Identification Properties (SNMP)
Add an Oracle ILOM User Account (SNMP)
Delete an Oracle ILOM User Account (SNMP)
Managing Other Aspects With Oracle ILOM (SNMP)
Set the HTTP Service State (SNMP)
Set the HTTPS Service State (SNMP)
Enable Alerts to Send SNMP Traps (SNMP)
Enable Alerts to Send PETs (SNMP)
Enable Alerts to Send Email Alerts (SNMP)
Modify Alert SNMP Version (SNMP)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Note - The entity numbers used in this procedure are for example only. Your entity numbers might differ, depending on the gateway firmware and configuration.
Note - The voltage values displayed for this procedure are in millivolts.
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.number
where number is the entity number.
For example, to display the current 3.3 VDC voltage, use the entity number respective to the /SYS/MB/V_3.3VMain voltage sensor target. This example uses entity number 4:
$ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.4 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.4 = INTEGER: 3249 $
The 3.3 VDC voltage displayed in the output of the example is 3249 millivolts, or 3.249 volts.
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.4 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.6 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.7 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.8 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.10 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.11 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.13 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.15 = INTEGER: volts(6) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.4 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.6 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.7 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.8 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.10 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.11 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.13 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.15 = INTEGER: -3 . . . SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.4 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.6 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.7 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.8 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.10 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.11 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.13 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.15 = INTEGER: none(1) . . . SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.4 = INTEGER: 3266 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.6 = INTEGER: 3351 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.7 = INTEGER: 11965 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.8 = INTEGER: 5018 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.10 = INTEGER: 3213 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.11 = INTEGER: 1006 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.13 = INTEGER: 1216 SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.15 = INTEGER: 2503 . . . SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.4 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.6 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.7 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.8 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.10 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.11 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.13 = INTEGER: reset(1) SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.15 = INTEGER: reset(1) . . . $
You can also filter the output of the snmpwalk command for a specific entity number. This is an example of filtering the snmpwalk command output:
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F ’.number =’
Note - The manner in which you can filter the output varies according to your operating system.
To filter voltage information for the 3.3 VDC main voltage, use the entity number respective to the /SYS/MB/V_3.3VMain voltage sensor target. This filtering example uses entity number 4:
$ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F ’.4 =’ SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.4 = INTEGER: volts(6) SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.4 = INTEGER: -3 SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.4 = INTEGER: none(1) SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.4 = INTEGER: 3266 SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMin.4 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMax.4 = INTEGER: 255 SUN-PLATFORM-MIB::sunPlatNumericSensorAccuracy.4 = INTEGER: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdNonCritical.4 = INTEGER: 3112 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdNonCritical.4 = INTEGER: 3402 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdCritical.4 = INTEGER: 3060 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdCritical.4 = INTEGER: 3454 SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdFatal.4 = INTEGER: 2958 SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdFatal.4 = INTEGER: 3539 SUN-PLATFORM-MIB::sunPlatNumericSensorHysteresis.4 = Gauge32: 0 SUN-PLATFORM-MIB::sunPlatNumericSensorEnabledThresholds.4 = BITS: FC lowerThresholdNonCritical(0) upperThresholdNonCritical(1) lowerThresholdCritical(2) upperThresholdCritical(3) lower SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.4 = INTEGER: reset(1) $
