Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Display the Switch Chip Port to QSFP Connector Mapping
Display Switch Chip Boot Status
Display Switch Chip Port Status
Display Switch Chip Port Counters
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Before You Begin
The output of some InfiniBand commands identify a node by its GUID. You can determine the switch chip or InfiniBand cable connection associated with that GUID using this procedure.
For example, given this output from the ibdiagnet command:
-W- lid=0x000f guid=0x002128312345c0a0 dev=48438 Port=21
In this example, the GUID is 0x002128312345c0a0 and the port is 21.
For example, GUID 0x002128312345c0a0 is truncated to c0a0.
The c0 means that the node is inside of a Sun Network QDR InfiniBand Gateway Switch. The a means that the node is located in I4 switch chip A, the only switch chip. The port is 21.
# ibswitches Switch : 0x03ba01234567a0a0 ports 36 "SUN DCS 36P QDR mnm-36p-2 10.172.144.66" enhanced port 0 lid 1 lmc 0 Switch : 0x002128312345c0a0 ports 36 "SUN IB QDR GW switch mnm-gw-1 10.172.144.69" enhanced port 0 lid 15 lmc 0 #
For example, using Switch Chip Port to QSFP Connectors and Link LED Routes, I4 switch chip, port 21 routes to connector 1B.
Gateway Reference, dcsport command
