Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Display Recent Subnet Manager Activity
Display Subnet Manager Priority, Controlled Handover State, Prefix, and Management Key
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Management Key
Clear the Subnet Manager Management Key
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
The Subnet Manager within the management controller is not enabled by default. Use the enablesm command to enable and start the Subnet Manager.
# enablesm Starting IB Subnet Manager. [ OK ] Starting partitiond daemon. [ OK ] #
