Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Accessing the Management Controller
Access the Management Controller From the NET MGT Port
Access the Management Controller From the USB Management Port
Discover the InfiniBand Fabric Topology
Perform Diagnostics on the InfiniBand Fabric
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
In the output of some hardware and InfiniBand commands, the switch is identified by its node description. The node description is of this format:
SUN IB QDR 36p switch hostname
where hostname is the host name of the management controller. An example node description might be:
SUN IB QDR 36p switch mnm34-97
