Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Display the Switch Chip Port to QSFP Connector Mapping
Locate a Switch Chip or Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Reenable Autodisabled Connectors
Delete Connectors From the Autodisable List
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
The dcsport command can also identify the connector of an InfiniBand device that maps to a GUID and port.
FabMan@switch_name->dcsport -guid guid -port port
where:
guid is the global unique identifier.
port is the number of the port (1 to 36).
For example:.
FabMan@switch_name->dcsport -guid 0x0021283a8980a0a0 -port 36 DCS-36P Switch port 36 maps to connector 6B FabMan@switch_name->
Switch Reference, dcsport command
