Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Floor and Underfloor Delivery of InfiniBand Cables
Overhead Delivery of InfiniBand Cables
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Proper InfiniBand cable installation requires the following:
Plan the cable routes and cable length needs.
Identify problematic cable route bends, minimizing the length of continuous vertical runs to no more than 2 meters (7 feet), and specify hardware to support cable routing.
Carry the entire cable to the points of connection and unroll the cable from the first connection point to the second
Keep the coil closed and pause to enable the cable to relax as it is unrolled and moved through turns.
Ensure that cable route turns are larger than 85 mm (3.4 inches) radius for optical cables and 127 mm (5 inches) radius for copper cables.
Find alternative routes for turns that are tighter.
Secure the cable to hard points and bundle it with soft, hook-and-loop fasteners.
Mediate the slack between securing points to maintain minimal cable tension and proper support.
See Floor and Underfloor Delivery of InfiniBand Cables and Overhead Delivery of InfiniBand Cables.
Label the ends of cables to identify their routes.
Rest the cable connectors on a stable surface when they are not connected.
