man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_acquire_cred(3GSS)
Name
gss_acquire_cred - acquire a handle for a pre-existing credential by name
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_acquire_cred(OM_uint32 *minor_status,
     const gss_name_t desired_name, OM_uint32 time_req,
     const gss_OID_set desired_mech, gss_cred_usage_t cred_usage,
     gss_cred_id_t *output_cred_handle, gss_OID_set *actual_mechs,
     OM_uint32 *time_rec);
Description
The gss_acquire_cred() function allows an application to acquire a handle for a pre-existing credential by name. This routine is not intended as a function to login to the network; a function for login to the network would involve creating new credentials rather than merely acquiring a handle to existing credentials.
If desired_name is GSS_C_NO_NAME, the call is interpreted as a request for a credential handle that will invoke default behavior when passed to gss_init_sec_context(3GSS) (if cred_usage is GSS_C_INITIATE or GSS_C_BOTH) or gss_accept_sec_context(3GSS) (if cred_usage is GSS_C_ACCEPT or GSS_C_BOTH).
Normally gss_acquire_cred() returns a credential that is valid only for the mechanisms requested by the desired_mechs argument. However, if multiple mechanisms can share a single credential element, the function returns all the mechanisms for which the credential is valid in the actual_mechs argument.
gss_acquire_cred() is intended to be used primarily by context acceptors, since the GSS-API routines obtain initiator credentials through the system login process. Accordingly, you may not acquire GSS_C_INITIATE or GSS_C_BOTH credentials by means of gss_acquire_cred() for any name other than GSS_C_NO_NAME. Alternatively, you may acquire GSS_C_INITIATE or GSS_C_BOTH credentials for a name produced when gss_inquire_cred(3GSS) is applied to a valid credential, or when gss_inquire_context(3GSS) is applied to an active context.
If credential acquisition is time-consuming for a mechanism, the mechanism may choose to delay the actual acquisition until the credential is required, for example, by gss_init_sec_context(3GSS) or by gss_accept_sec_context(3GSS). Such mechanism-specific implementations are, however, invisible to the calling application; thus a call of gss_inquire_cred(3GSS) immediately following the call of gss_acquire_cred() will return valid credential data and incur the overhead of a deferred credential acquisition.
Parameters
The parameter descriptions for gss_acquire_cred() follow:
desired_name
The name of the principal for which a credential should be acquired.
time_req
The number of seconds that credentials remain valid. Specify GSS_C_INDEFINITE to request that the credentials have the maximum permitted lifetime
desired_mechs
The set of underlying security mechanisms that may be used. GSS_C_NO_OID_SET may be used to obtain a default.
cred_usage
A flag that indicates how this credential should be used. If the flag is GSS_C_ACCEPT, then credentials will be used only to accept security credentials. GSS_C_INITIATE indicates that credentials will be used only to initiate security credentials. If the flag is GSS_C_BOTH, then credentials may be used either to initiate or accept security contexts.
output_cred_handle
The returned credential handle. Resources associated with this credential handle must be released by the application after use with a call to gss_release_cred(3GSS)
actual_mechs
The set of mechanisms for which the credential is valid. Storage associated with the returned OID-set must be released by the application after use with a call to gss_release_oid_set(3GSS). Specify NULL if not required.
time_rec
Actual number of seconds for which the returned credentials will remain valid. Specify NULL if not required.
minor_status
Mechanism specific status code.
Errors
gss_acquire_cred() may return the following status code:
GSS_S_COMPLETE
Successful completion.
GSS_S_BAD_MECH
An unavailable mechanism has been requested.
GSS_S_BAD_NAMETYPE
The type contained within the desired_name parameter is not supported.
GSS_S_BAD_NAME
The value supplied for desired_name parameter is ill formed.
GSS_S_CREDENTIALS_EXPIRED
The credentials could not be acquired because they have expired.
GSS_S_NO_CRED
No credentials were found for the specified name.
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
gss_accept_sec_context(3GSS), gss_init_sec_context(3GSS), gss_inquire_context(3GSS), gss_inquire_cred(3GSS), gss_release_cred(3GSS), gss_release_oid_set(3GSS), attributes (5)
Developer’s Guide to Oracle Solaris 11 Security
