man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
sip_add_header(3SIP)
Name
sip_add_header - add a SIP header to the SIP message
Synopsis
cc [ flag ... ] file ... –lsip [ library ... ]
#include <sip.h>
int sip_add_header(sip_msg_t sip_msg, char *header_string);
Description
The sip_add_header() function takes the SIP header header_string, adds a CRLF (carriage return/line feed) and appends it to the SIP message sip_msg. The sip_add_header () function is typically used when adding a SIP header with multiple values.
Return Values
The sip_add_header() function returns 0 on success and the appropriate error value on failure.
Errors
On failure, the sip_add_header() function can return one of the following error values:
EINVAL
Mandatory parameters are not provided, i.e. null.
EPERM
The message cannot be modified.
ENOMEM
Error allocating memory for creating headers/parameters.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
libsip(3LIB)
