man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_inquire_context(3GSS)
Name
gss_inquire_context - obtain information about a security context
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_inquire_context(OM_uint32 *minor_status,
     const gss_ctx_id_t context_handle,gss_name_t *src_name,
     gss_name_t *targ_name, OM_uint32 *lifetime_rec,
     gss_OID *mech_type, OM_uint32 *ctx_flags,
     int *locally_initiated, int *open);
Description
The gss_inquire_context() function obtains information about a security context. The caller must already have obtained a handle that refers to the context, although the context need not be fully established.
Parameters
The parameter descriptions for gss_inquire_context() are as follows:
minor_status
A mechanism-specific status code.
context_handle
A handle that refers to the security context.
src_name
The name of the context initiator. If the context was established using anonymous authentication, and if the application invoking gss_inquire_context() is the context acceptor, an anonymous name is returned. Storage associated with this name must be freed by the application after use with a call to gss_release_name(). Specify NULL if the parameter is not required.
targ_name
The name of the context acceptor. Storage associated with this name must be freed by the application after use with a call to gss_release_name(). If the context acceptor did not authenticate itself, and if the initiator did not specify a target name in its call to gss_init_sec_context(), the value GSS_C_NO_NAME is returned. Specify NULL if the parameter is not required.
lifetime_rec
The number of seconds for which the context will remain valid. If the context has expired, this parameter will be set to zero. Specify NULL if the parameter is not required.
mech_type
The security mechanism providing the context. The returned OID is a pointer to static storage that should be treated as read-only by the application; in particular, the application should not attempt to free it. Specify NULL if the parameter is not required.
ctx_flags
Contains various independent flags, each of which indicates that the context supports (or is expected to support, if ctx_open is false) a specific service option. If not needed, specify NULL. Symbolic names are provided for each flag, and the symbolic names corresponding to the required flags should be logically ANDed with the ret_flags value to test whether a given option is supported by the context. The flags are:
GSS_C_DELEG_FLAG
If true, credentials were delegated from the initiator to the acceptor. If false, no credentials were delegated.
GSS_C_MUTUAL_FLAG
If true, the acceptor was authenticated to the initiator. If false, the acceptor did not authenticate itself.
GSS_C_REPLAY_FLAG
If true, the replay of protected messages will be detected. If false, replayed messages will not be detected.
GSS_C_SEQUENCE_FLAG
If true, out-of-sequence protected messages will be detected. If false, out-of-sequence messages will not be detected.
GSS_C_CONF_FLAG
If true, confidential service may be invoked by calling the gss_wrap(3GSS) routine. If false, no confidential service is available through gss_wrap(). gss_wrap() provides message encapsulation, data-origin authentication, and integrity services only.
GSS_C_INTEG_FLAG
If true, integrity service can be invoked by calling either the gss_get_mic() or the gss_wrap() routine. If false, per-message integrity service is unavailable.
GSS_C_ANON_FLAG
If true, the initiator's identity is not revealed to the acceptor. The src_name parameter, if requested, contains an anonymous internal name. If false, the initiator has been authenticated normally.
GSS_C_PROT_READY_FLAG
If true, the protection services, as specified by the states of the GSS_C_CONF_FLAG and GSS_C_INTEG_FLAG, are available for use. If false, they are available only if the context is fully established, that is, if the open parameter is non-zero.
GSS_C_TRANS_FLAG
If true, resultant security context can be transferred to other processes through a call to gss_export_sec_context(). If false, the security context is not transferable.
locally_initiated
Non-zero if the invoking application is the context initiator. Specify NULL if the parameter is not required.
open
Non-zero if the context is fully established; zero if a context-establishment token is expected from the peer application. Specify NULL if the parameter is not required.
Errors
gss_inquire_context() returns one of the following status codes:
GSS_S_COMPLETE
Successful completion.
GSS_S_NO_CONTEXT
The referenced context could not be accessed.
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
gss_accept_sec_context(3GSS), gss_context_time(3GSS), gss_delete_sec_context(3GSS), gss_export_sec_context(3GSS), gss_import_sec_context(3GSS), gss_init_sec_context(3GSS), gss_process_context_token(3GSS), gss_wrap(3GSS), gss_wrap_size_limit(3GSS), attributes(5)
Developer’s Guide to Oracle Solaris 11 Security
