man pages section 3: Networking Library Functions
Exit Print View
Updated: July 2014
gss_release_buffer(3GSS)
Name
gss_release_buffer - free buffer storage allocated by a GSS-API function
Synopsis
cc [ flag... ] file... –lgss  [ library... ]
#include <gssapi/gssapi.h>
OM_uint32 gss_release_buffer(OM_uint32 *minor_status, gss_buffer_tbuffer);
Description
The gss_release_buffer() function frees buffer storage allocated by a GSS-API function. The gss_release_buffer() function also zeros the length field in the descriptor to which the buffer parameter refers, while the GSS-API function sets the pointer field in the descriptor to NULL. Any buffer object returned by a GSS-API function may be passed to gss_release_buffer(), even if no storage is associated with the buffer.
Parameters
The parameter descriptions for gss_release_buffer() follow:
minor_status
Mechanism-specific status code.
buffer
The storage associated with the buffer will be deleted. The gss_buffer_desc() object will not be freed; however, its length field will be zeroed.
Errors
The gss_release_buffer() function may return the following status codes:
GSS_S_COMPLETE
Successful completion
GSS_S_FAILURE
The underlying mechanism detected an error for which no specific GSS status code is defined. The mechanism-specific status code reported by means of the minor_status parameter details the error condition.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
Safe
See also
attributes(5)
Developer’s Guide to Oracle Solaris 11 Security
